90 D250 4x4 questions
Old Aug 27, 2005 | 05:31 PM
nzzytb's Avatar
nzzytb
Default 90 D250 4x4 questions
I just bought a 3/4 ton Dodge 4x4 with the 5.9L light duty emissions engine, 4 speed manual trans. I think it has a Dana 44 front axle and a Dana 60 rear. Can anyone tell me what model transmission I have and what transfer case I have? Also, is there any identification label or information on the truck that tells me what options were installed. I'm familiar with the service parts identification label on the GM stuff that gives all the options. Anything like this on the Dodge pickups? Thanks for your help.
Old Aug 28, 2005 | 05:46 PM
horatio102's Avatar
horatio102
Default RE: 90 D250 4x4 questions
You've probably got an NP208 t-case. Best way to tell is to crawl underneath with a rag and look for the round tag rivited to the back. As far as options go, not sure what to tell you. What are you looking for in particular? Axle ratio - should be a tag bolted to the diff cover that says what it's got. Limited slip? I recommend yanking the cover off and looking, since you just bought a 15 year old truck, it would be good to see what kind of shape the diff is in. Check for shavings and stuff in the oil.
