Speedo doesn't work
Old Sep 10, 2012 | 06:01 PM
Sniper X's Avatar
Sniper X
Default Speedo doesn't work
PO tells me it is the gear in the T case. How do I find the part number to order it? 1991, 4x4, manual 4 speed.....
Old Sep 10, 2012 | 06:08 PM
crazzywolfie's Avatar
crazzywolfie
you could put all the problems you are having with your truck in 1 thread. then we don't have to jump around from thread to thread.
you could try unscrewing the speed sensor from the t case and hook a drill to it so see if you speedo works. for some reason lots of people have the actual speedo mechanism go bad.
Old Sep 11, 2012 | 06:30 AM
SEAL's Avatar
SEAL
To answer the question. Take your info to a dealer and they will give you the proper part. The info needed is tire size, tranny, T-case, and rear gearing ratio. Unless you are sure your truck is totally stock this is an inexpensive way to get the right gear for an accurate speedo reading.
Old Sep 12, 2012 | 11:06 AM
Sniper X's Avatar
Sniper X
Point one, I am a member on many threads since I have 5 vehicles and 4 motorcycles and when I post 4~6 questions in one thread they all get ignored save for the first question....
Second po9int, The PO did do that as in he put a drill motor on the cable and it made the speedo work. I think he even told me he looked in the t case and saw the teeth on the gear worn down. So, I guess it isn't the speedometer itself.
Old Sep 12, 2012 | 11:57 AM
SEAL's Avatar
SEAL
It takes all of five minutes to pull the gear. Pull it out and look at it. You can drive it if needed without the gear in it as long as you put the outside back together. The weather is good, don't wait. JMO
Old Sep 12, 2012 | 12:27 PM
crazzywolfie
i agree with seal. there is only 1 bolt holding that gear in.
Old Sep 13, 2012 | 10:44 AM
Sniper X's Avatar
Sniper X
I am going to do that right after I figure out my new problem! I just found out this truck misses at low speed after a good hard rain. Any ideas on what might be getting wet?
