92 dodge level kit
Old Sep 18, 2012 | 04:51 PM
jcb11realtree's Avatar
jcb11realtree
Default 92 dodge level kit
is there a level kit that will fit a 1992 d150 2wd or can i use a level kit for a 1994 ram 1500 2wd
Old Sep 18, 2012 | 06:09 PM
1991ram's Avatar
1991ram
94 is a 2nd gen it wont work
Old Sep 18, 2012 | 07:29 PM
wontacceptthis's Avatar
wontacceptthis
You can use spring spacers, or possibly d250 springs.
Old Sep 18, 2012 | 08:13 PM
SixGun's Avatar
SixGun
I've been told by a guy that does lifts at his shop that the coil spring spacers for the 94 up will work BUT 2" is max because of balljoint articulation. There's spring shops out there that will make lifted coils for your 2X truck also. I used Coil Spring Specialty and there's also Eaton Springs. Same thing 2" max. D250 is used a lot but remember it will be stiffer.
Old Sep 18, 2012 | 08:19 PM
crazzywolfie's Avatar
crazzywolfie
i was told my ramcharger had heavier duty springs put in it. not sure what people consider heavy duty but it rides fairly good to me. i also have an extra leaf in the rear.
