Back Fire
Old Sep 27, 2012 | 04:10 PM
playgun's Avatar
playgun
Default Back Fire
I have a 90 250 with the z vin 360. Sometimes at part throttle when i am just starting out it will stutter or hesitate and backfire through the throttle body. It has new plugs and fresh fluids. It had some vacume issues but i fixed that. It has done this since i got it a couple months ago. It isnt weak and it only does it a low rpms and part throttle. any help would be appreciated
Old Sep 28, 2012 | 06:26 AM
SEAL's Avatar
SEAL
Have you checked the timing?
Old Sep 28, 2012 | 06:44 AM
rwspellman78's Avatar
rwspellman78
sound like ur timing is just a lil advanced to much
Old Sep 28, 2012 | 07:03 PM
playgun's Avatar
playgun
I got it fixed, the timing was 5° retarded I put it at 14° advanced and it runs like a champ now.
Old Sep 28, 2012 | 09:29 PM
SixGun's Avatar
SixGun
If I'm not mistaken, you should be at 10* BTDC.
Just in case, the procedure is to warm up your engine then disconnect your coolant temp sensor. This will keep the timing mark from fluctuating while trying to time it.
Old Sep 29, 2012 | 01:05 PM
playgun's Avatar
playgun
I tried it at 10° btdc and it still hesitated so i turned it on up to 14 and that seems to be the magic number. The timing chain may have some stretch in it but i will put a new one on thos winter when i put in a mild towing type cam any recomendations on which cam?
