How to convert a 318 to a 340?
Old Sep 30, 2012 | 03:37 PM
dairy's Avatar
dairy
Default How to convert a 318 to a 340?
I have a 318 laying around that I wanted to rebuild to a 340. What has to be done to achieve the same specs as an original 340?
Old Sep 30, 2012 | 04:46 PM
charlie1935's Avatar
charlie1935
318 & 340 had the same stroke but the 340 had 4.04 bore, 318 3.91 bore. It can't be bored that much.
You could go with a stroker kit and get as much as 390 CID.
Old Oct 2, 2012 | 07:52 PM
dairy's Avatar
dairy
So how much can you bore a 318 would be a better question.
Old Oct 3, 2012 | 06:07 AM
SEAL's Avatar
SEAL
60 over seems to be the max.
Old Oct 3, 2012 | 03:50 PM
Sniper X's Avatar
Sniper X
Bore it 60 over, put in a set of HC pistons, and good rings, then use a hotter cam and headers and good dual exhaust. Add a good aluminum intake and a Carter or Edelbrock carb and you'll be very pleased at the power. Back when you could still get a 340 in Dusters and such, a guy here had a built up 318 in his Duster. He would slay all the 340 based Dusters save for the one that had basically the same mods he did and that was a close race.
