91 d250 tail lights not working
Old Oct 11, 2012 | 02:06 PM
93dak4x4's Avatar
93dak4x4
Angry 91 d250 tail lights not working
I am trying to help a friend fix his tailights on a 1991 d250, he has head lights turn signals and brake lights but the park and tail lights are not working. Initially I thought there might be a problem with the light switch and at one point the park lights came on while I was messing around under there, however even after putting in a new switch the tail lights still wont work and now I cant get park lights either.
Any thoughts would help.
Old Oct 11, 2012 | 02:35 PM
crazzywolfie's Avatar
crazzywolfie
from the wiring diagram i am looking at there should be a black wire with a yellow stripe that runs from the headlight switch to the park lights and rear lighting. check fuse number 4.
Old Oct 11, 2012 | 03:37 PM
93dak4x4's Avatar
93dak4x4
all fuses checked and good. The problem started when he had trailer harness attached and pinched wires causing all wires to cross.
Old Oct 11, 2012 | 04:32 PM
crazzywolfie
well if the problem started with the trailer wiring that's where I would start my search. black wire with a yellow stripe should be the one you are looking for
Old Nov 10, 2012 | 09:00 PM
99sport's Avatar
99sport
I had the same problem with my 81 and it was where the wire from the headlight switch goes through the fire wall.
Old Nov 12, 2012 | 08:36 AM
Scooter78's Avatar
Scooter78
When I read the issue before going through all the info you posted, I though "Ill bet it has a trailer connector and something is jacked up with that." Then I saw you mention trailer wiring. I would look there first, without a doubt.
Old Nov 12, 2012 | 05:44 PM
dairy's Avatar
dairy
I had a similar problem but only the brake lights didnnt work. Turns out if i pull my hazard switch it would prevent my brake lights from coming on.
