Are my u joints bad? And could i fix them myself?
Old Nov 2, 2012 | 10:44 PM
Its turbo time's Avatar
Its turbo time
Got the shaft out, I'm gonna take it to my parents tomorrow to use my dads vise.
I hit the u joints with WD-40. I did not see any clips on the outside of u joints though.
Old Nov 2, 2012 | 10:54 PM
crazzywolfie's Avatar
crazzywolfie
they are on the inner side. the c clip hold the end caps from being able to slip out.
Old Nov 3, 2012 | 01:22 AM
SixGun's Avatar
SixGun
U-joints are fairly inexpensive and while you have it removed already you might as well change the other as preventative maintenance. When I did mine, I backed up the driveway since it is on an incline for me. That keeps most of the fluid away from the end of the tranny when you pull the yoke out. Don't let the caps fall off the new u-joints. Those little needle bearings are a pita to find. LOL A clean work area, big vise, heavy mallet, and sockets to drive out the caps are all you need. Be sure to watch the video too. Also, you want to get HD units with grease fittings so you lube them.
Old Nov 3, 2012 | 09:27 AM
Its turbo time
I didn't notice any fluid coming out of the tranny when I pulled the yoke, will it seep out of it slowly?
Old Nov 3, 2012 | 03:27 PM
Its turbo time
The new u joint went in much easier than the old one came out!
Old Nov 3, 2012 | 06:35 PM
SEAL's Avatar
SEAL
The rust usually puts up some pretty good resistance. If the truck was level I would check the trans fluid level just to be sure. I have pulled my shaft out and had no spillage of fluid. It just depends on how the truck is sitting.
Old Nov 4, 2012 | 09:56 AM
Its turbo time
Thanks, it was pretty level. It dripped a little bit, but I'll still check the fluid, good call
Old Dec 16, 2012 | 02:16 PM
Its turbo time
I guess I was wrong about the problem being the u joint. After I changed the one I never really took the van on any longer drives, well last night I had it on the highway for about 20 minutes and when I got off the highway it started making the same noise again. It seems to make more frequently when I turn one way when compared to the other.
Seems that once it been on the highway a while something gets warm enough to make that noise, but when it's cold it doesn't do it.
Old Dec 16, 2012 | 03:20 PM
blindsided's Avatar
blindsided
Sounds more like a hub bearing to me
Old Dec 16, 2012 | 03:31 PM
Its turbo time
How do I check that? Jack up the rear end and Shake the wheel?
