1990 Ram D250 ignition cylinder
Old Nov 28, 2012 | 04:42 PM
tph3576's Avatar
tph3576
Default 1990 Ram D250 ignition cylinder
New to this forum, just bought a 1990 D250 from a guy I work with. The ignition cylinder was broken out of it when it got stolen 3 years ago. I can get a new cylinder for $20. Question is how is it held to the column? The buzzer switch is broke but that's no biggy. I cannot see where a new cylinder would bolt up. There is a lever of sorts on the column which is how you start the truck now. If anyone has knowledge or pics of a good column for reference that would be helpful. Thanks
Old Nov 28, 2012 | 05:09 PM
SEAL's Avatar
SEAL
If nothing else is broken a new lock cylinder just snaps into place once it and the ignition switch are in the lock position. You must remove the steering wheel and other stuff to gain access to the lock cylinder removal hole when taking one out.
