'84 3/4T front axle into '86 RC
Old Dec 1, 2012 | 10:01 PM
440rc86's Avatar
440rc86
Default '84 3/4T front axle into '86 RC
I was browsing the boneyard for a 3.55 front axle for my '86 Ramcharger. I wanted one w/o the split axle, sliding collar setup, and found a 44 axle in an '84 3/4 ton P/U. What I'm wondering is...can I make this axle work in place of the 44-8FD with manual hubs? Could it be as simple as swapping spindles?
A little background: I put a 440/auto/203 w/part-time kit in my '86 RC. I have swapped out the 3.23 rear axle for a 3.55 and now need to do the front.
Thanks for the help!
Old Dec 2, 2012 | 09:38 PM
440rc86's Avatar
440rc86
Any axle guys out there?
What I'm thinking of doing is take the manual hubs/spindles off the 1/2 ton axle and put them on the 3/4 ton axle. Would that work? Thanks
Old Dec 3, 2012 | 04:50 AM
sls001's Avatar
sls001
Yes, you need to swap everything from the c's outward (spindle, hub, knuckle, etc.)
The D44 and D44HD are basically the same axle...
Old Dec 4, 2012 | 12:12 AM
440rc86's Avatar
440rc86
Ok, got it, sounds good. What do you mean "c's"... that flat flange on each end of the housing with about 6 bolts?
Old Dec 4, 2012 | 05:53 AM
sls001's Avatar
sls001
Sorry, the "C" I'm referring to is the welded to the axle tube . You need to replace all the parts from that point out.
