Ticking in upper end of the engine. 87 d100 318
Old Dec 11, 2012 | 07:08 PM
87ramman's Avatar
87ramman
Default Ticking in upper end of the engine. 87 d100 318
There has been a constant ticking in the upper end of my 318, being a former chevy guy I had thought it was just the rockers needing adjusted. However, upon more research I found out that it can't really be the rockers. Do ya'll have any ideas on where the ticking could be coming from?
Old Dec 11, 2012 | 07:32 PM
crazzywolfie's Avatar
crazzywolfie
usually a tick in the top end is a lifter. most older trucks tick for a couple seconds after start up until oil starts flowing. have you checked the oil level?
Old Dec 11, 2012 | 07:51 PM
SEAL's Avatar
SEAL
Low oil level or too low a viscosity oil are the first possibilities. It could also be a bad rocker, bent push rod, or collapsed lifter.
Old Dec 16, 2012 | 09:30 PM
87ramman's Avatar
87ramman
I also just discovered a head gasket leak, how hard/ how long would you say a job like this would take?
