help please out of ideas
Old Dec 19, 2012 | 10:12 AM
crazzywolfie's Avatar
crazzywolfie
does it seem to blow gas or air out the throttle body when you go to start it?
Old Dec 19, 2012 | 12:24 PM
SEAL's Avatar
SEAL
At TDC the rotor can point directly at #1 or directly away from #1. That is why I said TDC with the #1 cylinder in firing position. Remember the crank turns twice for every rotation of the cam. That means the crank has 2 TDCs for every one full rotation of the distributor.
Old Dec 19, 2012 | 04:31 PM
gregfugate11's Avatar
gregfugate11
when I first started messin with it it was burpin fuel up thru the throttle body but once I pulled the distributor and everything it stopped and it would run but only at wot which makes me wonder if I might have goofed an put it in 180 out it wouldn't be the first time I know I had number one on the compression stroke would 180 out would make it hard to start like I have to keep it held to the floor and once it does I still have to or it dies as soon as I let off just a little bit ?
Old Dec 19, 2012 | 04:50 PM
SEAL's Avatar
SEAL
I would bring it to TDC, pull the distributor, and turn the distributor 180 from where it is. That is the easiest way to find out if it is 180 out. Unless you want to pull the drivers valve cover so you can tell if both valves are closed which would mean it is at TDC in the firing position.
Old Dec 19, 2012 | 05:12 PM
gregfugate11
ill do that and see what happens I plan on puttin new valve cover gaskets on anyway just not this soon I'm gonna spin the dizzy 180 first though we'll know by mornin if it fixes it
Old Dec 19, 2012 | 05:21 PM
crazzywolfie
does it blow gas or air out the throttle body when you try to start it? usually that is one of the symptoms of having the distributor being 180* off. just have to take the air cleaner off to check.
Old Dec 19, 2012 | 05:43 PM
gregfugate11
when I frist got it home and tried to start it it was blowing fuel out the throttle body which made me think the previous owner had put the dizzy in 180 out but after I pulled it an put it at tdc it stopped and my issue went from that to only starting with the pedal on the floor and only running at wot
Old Dec 23, 2012 | 08:05 PM
gregfugate11
Angry
well, finally got to mess with the truck today brought it around to tdc again and turns out the dizzy was 180 out hit the key sounded and acted like she was gonna fire up... Backfired once then nothin' Im not sure what to check firing order is right done everything by the book even checked all the plugs they are nearly new any ideas this motor has only 40000 after rebuild
Old Dec 23, 2012 | 08:12 PM
crazzywolfie
are you sure it was 180* off? the crank turns 2 times for every 1 rotation of the cam so you have 2 top dead centers so it can sometimes look like you are 180* off but are not.
Old Dec 23, 2012 | 08:20 PM
gregfugate11
Well at tdc on the compression stroke the rotor was pointin at the firewall instead of number one
