need help slant 6 to a 318
Old Jan 17, 2013 | 07:34 PM
maxima2fst4u's Avatar
maxima2fst4u
New Member
Default need help slant 6 to a 318
ok i had this set up in my old dodge it was a 1986 it had the a833 4 speed 318 with 360 heads 4bbl carb high rise intake headers hurst shifter the works..ok im getting the same truck just about but it has the slant 6 in her but still the same tranny...i know i need a different bell housing do to the starter issue and stuff but what else do i need?? like for the wiring issue and clutch set up and the size for the clutch and the fly wheel...any one done this swap let me know with the stuff i need please or some advice pls ty mopar fam
Old Jan 19, 2013 | 03:47 PM
grimm's Avatar
grimm
I dropped a 400 B block into my '85 that had a /6 and A833 OD combo. I used the 143 tooth flywheel and 11" clutch that came with the engine, bought a dual patter NP435/A833 bellhousing from mopartruckparts.com, used the mini starter off the /6, and I reused the z bar, I just had to adapt it a little bit. On the /6 bellhousing it bolted to the bell with a little bracket and 2 bolts, for the big block theres a post that screws into the bell. Not sure what diffrences you'll find with the 318, hope this helps.
