SMOG issue
Old Jan 19, 2013 | 06:42 PM
Sniper X's Avatar
Sniper X
Default SMOG issue
When I got my truck back in early September, the day I got it I had it SMOG checked and it passed with flying colours. SOOOO. Fast forward to three months down the road, and now that I HAVE to get it plated, I have a slight problem! It failed SMOG yesterday on idle it had almost twice the allowable CO but everything else was good. It even passed on high rpm on both CO and HC. How the hell do I adjust the idle CO? Is there a way? Or is that done by the computer? I am thinking it is a partially clogged low speed injector for some reason. BTW if it means anything, my air filter was also very dirty and the gas cap failed smog too....
heres the readings...
Old Jan 19, 2013 | 10:31 PM
crazzywolfie's Avatar
crazzywolfie
fixing the gas cap and cleaning or replacing the air filter is a good idea. did you bring it into the emissions place hot? could maybe try running a bit higher octane gas.
Old Jan 20, 2013 | 01:19 PM
Sniper X's Avatar
Sniper X
I replaced the gas cap and air filter and saw that the air filter was the wrong size in the housing. Plus it was very dirty. I also got some of that stuff called G2P garenteed to pass, an filled up with premium since I had low test in there. I hope with these things it will pass tomorrow. Oh, and yes it was fully warmed up when I took it in for the test.
Old Jan 20, 2013 | 09:47 PM
sls001's Avatar
sls001
Your running rich at idle...I didn't see any truck info what year, eng, etc are you trying to get through?
Old Jan 21, 2013 | 02:38 PM
Sniper X's Avatar
Sniper X
1991 w150 4 speed, 318, all dead stock with all original equipment. No check engine lights or displays on the dash. I am chancing my plugs today as well just for the hell of it.
Old Jan 21, 2013 | 02:49 PM
crazzywolfie
you should really put that info in your sig or put it in the vehicle information box. then we would not have to ask you the same question every time you ask for info or help.
Old Jan 21, 2013 | 03:09 PM
sls001's Avatar
sls001
Sill you should check for codes. Also check for dripping injectors while it is idling.
Old Jan 22, 2013 | 10:42 PM
wontacceptthis's Avatar
wontacceptthis
Maybe try turning the idle up. Isn't the high limit for the idle test around 900rpm?
Old Jan 24, 2013 | 11:26 PM
Sniper X's Avatar
Sniper X
it is idling low, or was around 735...
Old Jan 25, 2013 | 09:54 PM
moe7404's Avatar
moe7404
try and spike the gasoline with methanol. a LOT
