weird noise from drive line/ wheels
Old Feb 6, 2013 | 08:00 PM
tnc110's Avatar
tnc110
New Member
Default weird noise from drive line/ wheels
85 d100 2wd auto. Truck makes a weird thud/knocking noise especially when turning left at speed (pretty much any speed ) and sometimes when going straight. The noise sounds like a bad shock rattling when going down a rough road or exhaust smacking the frame. It also seems to be speed dependent...the faster I go the more knocks/thuds. New front rotors, bearings, calipers and pads. All shocks seem to be tight and right. Motor mounts look good. Tires are new. Doesnt seem to be any play in A arms or any front end parts....all seems pretty tight. Any ideas?
Old Feb 6, 2013 | 11:59 PM
go-part's Avatar
go-part
Former Vendor
Have you checked the CV joints? Check the boots for cracks and leaking grease.
Old Feb 7, 2013 | 07:56 AM
tnc110's Avatar
tnc110
New Member
2wd truck. universals look/feel good. makes same noise in any gear or in neutral. when I first take off in the truck the noise isnt noticeable, until I put about 1/4 mile on the truck then it starts. the cab seems to amplify the noise, when i open the door and lean out going down the road to try to listen, the noise is less.
Old Feb 7, 2013 | 11:20 AM
SixGun's Avatar
SixGun
Double check your motor mounts and transmission mount too. I would really think that it's the driver's side mount because of the turning left thunk you mentioned. My old mounts looked fine until I hit a deep hole and the old rubber just tore apart.
