1/2 ton to full one tun
Old Feb 17, 2013 | 10:59 AM
camd94234's Avatar
camd94234
Default 1/2 ton to full one tun
So i can get my hands on a set of dana 60s srw 4.10s front and rear axles for 200 bucks a piece.. Thing i need to know if will i be able to use the same drive shafts? And will i i still be able to use 15 inch rims but ofcorse i will need the 8x6.5 bolt pattern.
Thanks,
Cam
Old Feb 17, 2013 | 01:23 PM
nmrockcrawler's Avatar
nmrockcrawler
Drive shafts from the half ton will not work with the Dana 60 yokes. The 60's will have a bigger yoke. When I put a 60 in the rear of my 74 power wagon I had to go to a rear cv drive shaft with a 1350 u joint I believe.I had 4.10's and a power loc and that truck went every where I wanted it to go.
Old Feb 17, 2013 | 02:34 PM
camd94234's Avatar
camd94234
Why did u need the cv driveshaft? In the rear?
Old Feb 18, 2013 | 10:48 AM
nmrockcrawler
I.needed the.cv.drive shaft in the rear because the.truck had 8" skyjacker lift springs on it and the pinon angle was to extreme for a standard shaft and also because I used it mostly for crawling so the shaft was also long travel. The power wagon had alot of mods done to it.
Btw I am jealous you.can get those 60's for $200 a piece.
