Fuel pressues regulator vacuum
Old Feb 23, 2013 | 07:56 PM
ConquestTurbo87's Avatar
ConquestTurbo87
Default Fuel pressues regulator vacuum
How much vaccuum should u have at the FPR nipple on the back of the tb at idle, mid, and wot??
Old Feb 23, 2013 | 08:27 PM
crazzywolfie's Avatar
crazzywolfie
i would guess the vacuum readings would be the exact same as you would get at any of the vacuum ports on the engine.
Old Feb 24, 2013 | 09:21 AM
ConquestTurbo87
I have zero pressure. Not really sure how that can be.
Old Feb 24, 2013 | 11:37 AM
sls001's Avatar
sls001
The regulator has what appears to be a vacuum line. This is NOT a vacuum line, nor should it be hooked to a vacuum source. It simply collects vapors from a failing regulator for emission purposes.
Edit: provided we are talking about specifically about TBI engines
Old Feb 24, 2013 | 11:52 AM
ConquestTurbo87
Ok thx for the info ill keep digging for my problem
Old Aug 23, 2018 | 10:28 PM
increa's Avatar
increa
Well... the tube doesn't just end in mid-air. What ~does~ it connect to? If it's collecting vapors from a failing regulator, where does it take them? What is on the other end of the line?
