Anyone done a headlight brightener? You know the relay thing....
Old Mar 4, 2013 | 04:03 PM
  #21
Sniper X's Avatar
Sniper X
The ground wire on the stock harness was about 22ga it looked like. I couldn't believe it was SO wimpy!
Old Mar 4, 2013 | 04:11 PM
  #22
crazzywolfie's Avatar
crazzywolfie
i was thinking the exact same thing when i notice it a couple weeks ago. according to the diagrams it is actually a 20 gauge but that is still pretty week compared to the 16 gauge they used on my 81 from the factory
Old Mar 5, 2013 | 08:02 AM
  #23
Scooter78's Avatar
Scooter78
My diagram is showing 20 gauge on them as well, and when I put a meter to them, I am only getting 12.1 volts while running. My harness appears to be in great shape. Im very excited for this mod.
As wolfie said, mine is a '78 W350.
Old Mar 5, 2013 | 10:45 AM
  #24
Sniper X's Avatar
Sniper X
I say go for it! It is fun to do as it is easy if you have a working knowledge of DC electronics like I do and it makes a huge difference for the low dollar cost. PLUS you can go to a different H4 headlight housing and brighter lamps as well so get even more light out of the truck.
Old Apr 18, 2013 | 05:53 PM
  #25
Sniper X's Avatar
Sniper X
Update, still working perfectly and after driving it a few times at night, what a difference! WHITE BRIGHT light compared to a couple candles behind the glass. I am getting some housings that take H4s and are a way more effecient and better pattern plus some 80~110 bulbs. Now that my wiring will support it and am getting a high amp alternator, a 140a job.
Old Apr 18, 2013 | 06:08 PM
  #26
crazzywolfie
glad they are still working good for you. do you know what alternator you currently have? only reason i ask is i think they offer 3 different alternators in 91 and i think they are all interchangeable. 75/90/120amp. only reason i mention this is because i know that sometimes those bit higher amp alternators cost a bit more and rock auto lists the 75 amp alternator for about the same price as the 120 amp alternator.
Old Apr 18, 2013 | 06:32 PM
  #27
Sniper X's Avatar
Sniper X
I am just guessing, but I probably have the lowest amp alt in mine. Although I will check. I wonder who I can tell? Do you knwo where I might be able to find out which one it is?
Old Apr 18, 2013 | 07:03 PM
  #28
crazzywolfie
should say on the alternator. there should be a tag on it. i think it should say something like family 75hs, family 90hs or family 120hs. not really sure since i only have a 75 and 90 amp alternator. could also try looking up the part numbers on the tag.
Old Apr 19, 2013 | 10:31 AM
  #29
Sniper X's Avatar
Sniper X
Cool Crazy! Thanks!.
Old Apr 19, 2013 | 06:20 PM
  #30
Comrade General's Avatar
Comrade General
Does this mod use the stock switch?
