engine to frame ground
Old Mar 8, 2013 | 12:15 PM
ghonhee's Avatar
ghonhee
Default engine to frame ground
Hello. The ground that comes off the engine and bolts in to the bottom/back of the hood has broken up. I'm trying to run a new ground. Where does the cable lead on the engine end? Thanks
Old Mar 8, 2013 | 12:19 PM
crazzywolfie's Avatar
crazzywolfie
i think on a 91 the ground cable at the back of the engine usually bolts to the head and runs up to the bolt that holds the coil bracket to the firewall.
Old Mar 8, 2013 | 06:41 PM
ghonhee's Avatar
ghonhee
Thank you.
