horn doesnt work
Old May 4, 2013 | 12:27 PM
Turner661's Avatar
Turner661
Default horn doesnt work
hey guys just got new w150 and only thing that doesnt work is the horn and the amount of traffic and people i love to flip off its hard without a horn. im most likley going to be installing my dixie horn but can i install the dixie horn to the steering wheel or should i replace the normal horn to steering wheel and make a button for dixie?
but regardless anyone know how to fix he horn
Old May 4, 2013 | 07:58 PM
wontacceptthis's Avatar
wontacceptthis
Does your cigarette lighter work? They are on the same fuse. I'd start there.
Old May 4, 2013 | 08:07 PM
sls001's Avatar
sls001
Check the fuses if ok
Use a test light and press the horn button and see if you have power to the horns.
If you have power, the horns have failed or have a bad ground.
Old May 6, 2013 | 01:40 AM
Turner661's Avatar
Turner661
oh haha yea theres no fuse in it i put a 15 in it cause thats all i had kicking around what fuse number should i use?
Old May 6, 2013 | 02:55 AM
crazzywolfie's Avatar
crazzywolfie
i think it is suppose to be a 20 amp fuse in there
Old May 6, 2013 | 12:31 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
^20 amp sounds about right.
You need to figure out what CAUSED the original fuse to blow, so you don't end up blowing it again or causing the truck to burn down.
And we want more pictures of that old beast.
Old May 6, 2013 | 10:08 PM
crazzywolfie
sounds like there was no fuse in the holder at all. if he is using a 15 amp the fuse should blow long before the truck tries catching fire.
Old May 7, 2013 | 10:52 AM
Sniper X's Avatar
Sniper X
So did the 15a fuse make the horn go TOOT?
Old May 7, 2013 | 12:09 PM
Turner661's Avatar
Turner661
hey sorry late responce on it. okay so i put the 15 in and no toot toot :/ but also havent had time to take pics. hhaha been so busy driving it till she blows over (therostate needs replaced) but i put new exhaust on it and it now sounds like a big block lol haha boy does she purr! but its gone back to the shop i bought it from cause they said they would fix all the problems. but parts were on order so they will be fixing thermostate and i think they said horn. and the cable for my oil temp. so ill get some pics and maybe a vid or two within the week.
Old May 7, 2013 | 01:36 PM
Mr.Clean27320's Avatar
Mr.Clean27320
That sounds good. So, what did you have done to the exhaust, new mufflers and pipes or just mufflers, and what kind and size?
