1991 W150 Steering sloppy
Old Jul 7, 2013 | 11:44 PM
dcdoc45's Avatar
dcdoc45
Default 1991 W150 Steering sloppy
1991 W150 v6 power steering:
My question is, the steering is very "loose", I turn the wheel and it takes a more motion than it should. I looked at the rag joint, it is fine, I looked down by the steering gear, and where the shaft goes into the gear box is some kind of coupler. It is very worn. I can turn the steering shaft by hand and there is a lot of play in that coupler. My question is, can I rebuild this coupler? What is the proper name for it so I can get another one, or rebuild this one?
Old Jul 8, 2013 | 12:03 AM
crazzywolfie's Avatar
crazzywolfie
you can rebuild the coupler. rock auto lists it as a Steering Shaft Repair Kit. DORMAN Part # 425253
Old Jul 8, 2013 | 08:10 AM
charlie1935's Avatar
charlie1935
Here they are. Kit and slip joint.
424-252 for joint
424-253 for kit
I needed both the last time I did mine.
Oops! Didn't see the number you posted, Wolfie.
Attached Thumbnails 1991 W150 Steering sloppy-steering-slip-joint-424-252.jpg   1991 W150 Steering sloppy-strng-repair-kit-424-253.jpg
