1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I went to open the hood and the inside cable hood relese broke. Can someone please tell how I can open the hood to put a new cable in? I surely would appreciate it. My truck is a 1987 Dodge Ram 4X4.
Did the cable break inside the cab? If so, get a pair of pliers on the wire cable inside the housing and give it a tug, you may also want someone to bounce the hood up and own while you do that to help release some tension on the cable and hood lock.
RE: Chump, the cable broke at the release lever under the hood
I used a long thin screwdriver to push the lever where the cable attaches on a friend's neighbor's truck. Worked fine. At that point you could either swap the hood latch from an older truck (grill release instead of in-cab) or put a new cable in.
