Replacement transmission cooler lines for 92' W150
Old Aug 12, 2013 | 11:07 PM
GroundLoop's Avatar
GroundLoop
Post Replacement transmission cooler lines for 92' W150
Already replaced all the fuel and brake lines. Tranny lines are looking real bad. I searched the forums, eBay, and general Google search and cannot find them. Do they exist or do I need to bend my own?
Old Aug 12, 2013 | 11:14 PM
crazzywolfie's Avatar
crazzywolfie
i think you just need to make your own. i don't think there is anything special to them. i think they would be the same steel and rubber lines that you would have used to replace the fuel lines.
Old Aug 14, 2013 | 02:01 AM
moe7404's Avatar
moe7404
for tranys cooler lines use ONLY steel brake line tubing. same for fuel lines, and oil lines. any thing else will break. some times the factory does things right. never use nylon for oil lines, it has a habit of cracking. ie its brittle.
