1991 dodge w250
Old Dec 29, 2013 | 10:30 AM
spcchapel's Avatar
spcchapel
Default 1991 dodge w250
my 1991 w250 with 5.9 ltr cummins turbo diesel has a problem, when its in park the volts reads 12 and the head lights are bright put it in gear volts go around 8 head lights almost ofradio flashing all the dash is blinking put it in park again and back to 12 volts
Old Jan 1, 2014 | 11:13 PM
Comrade General's Avatar
Comrade General
If its cold that could be the grid heater cycling. The volts will drop and go back up a couple times while the truck warms up. Its enough to dim the headlights.
But if its only doing it when you put it in drive, idk. Could be short.
Old Jan 2, 2014 | 11:55 AM
xjarhead69's Avatar
xjarhead69
Pull the voltage regulator off the firewall and make sure it has a good clean ground.
Dave
