360 to a 408 stroker
remember i think the stock 360's back then pushed under 200hp and ft pds of tq
There is nothing wrong with the factory fuel injection. It is a dead simple system but people are to lazy to properly diagnose the problems, instead they get a problem and keep throwing parts at it to try and fix it and end up spending a fortune.
To the OP make sure you check your timing, basic tune up items, etc. Your truck should be able to tow with no problems.
OP my Carb'd 4 speed 85 360 would have no issues towing a trailer that size right now, it has towed much heavier ones and only has like 3.23 gears but honestly uphill into the wind I too would want more power
Yes, the rated hp and tq is very low for that year. I want to bump the timing up, but I'm unsure if and how you can with it being all part of the tbi control unit. I've built a few carb dodge motors and was very impressed with the 318s hp and tq with a mild tq cam on regular hydraulic lifters. This motor has a roller cam and I don't know if I can change them out to regular lifters. The roller cams are very pricey. However, if the power gain is worth the money, I would go that route. My other dilemma is I have to keep the air system for emissions. I know the air pump takes very little power to run, so I can work around that. I'm just needing some advice for a decent build and I thought a stroker was the way to go.
120-125 is ok but the number is also dependent on the altitude where he lives. A number of things affect the outcome of the compression test; cranking speed, temperature, altitude, worn cam lobes, worn timing chain\gears, etc.
I didn't see how many miles are on this truck but you might want to check for excessive wear in the timing chain\gears by performing a deflection test on it.
