lean Burn removal/ Elec. Ignition install- Help
Old May 19, 2014 | 11:58 AM
emnestor's Avatar
emnestor
Default lean Burn removal/ Elec. Ignition install- Help
I am at the point in my build that I have to get after the electrical. I am useless with electrical. Anyway, I am trying to remove the "Lean Burn Box" and install the standard Mopar Electronic Ignition. Can I just disconnect the plugs and throw the box out when I am finished????
I ask because I couldnt get past step 1 of the Elec Ignition install (Finding the MIF wire from the ignition run position) without connecting the lean burn box back up.
1987 Dodge D100 with 318
