88 powerram 100 fuel problem
Old Jun 20, 2014 | 07:34 PM
mr.318's Avatar
mr.318
Default 88 powerram 100 fuel problem
Just bought it t.b.i.guy just put new pump fuel regulator, and relay,an filter.on it It still wasn't getting fuel Now I pulled tank found supply hose had a hole in it, Replaced hose idles fine revs fine in park, but driving acts like it's bogging out, once at steady speed it's fine, I checked fuel pressure 15 lbs.but when I pinch the regulator hose it stays the same don't go up to 18 lbs like manual says ? Theres no vacume at either end of regulator hose not even when I give it gas ? What could cause this yes I have tuned it up thinking the new regulator is bad
