89 D250 Coil Spring change
Old Dec 2, 2014 | 02:33 PM
sawitup's Avatar
sawitup
Default 89 D250 Coil Spring change
Any tips on changing out the front coil springs on my 89 D250? I purchased some Moog 7226s coil springs to go in there. Is there a write-up somewhere? I have the Chrysler service manual and it doesn't cover suspension at all.
Old Dec 4, 2014 | 11:42 AM
emnestor's Avatar
emnestor
Just did mine. use a floor jack under the lower arm to hold the tension of the spring when you break loose your ball joint. Also leave the upper and lower ball joint nuts on just at the end of threads to prevent the spring from popping all the way out when you break the joints loose. Slowly lower the jack stand to release the spring tension. When installing your new ones attach the strut rod to the lower arm before you put the springs in. Leave it very loose. It can be a pain sometimes getting that strut back in after the spring has all the tension on it.
Old Dec 26, 2014 | 07:59 PM
SixGun's Avatar
SixGun
For the strut rod, I used a longer threaded bolt to pull the strut close to the control arm until I could get the original bolt in the second hole. I used the free tool rental at Auto zone to remove and replace the coils. Its safer and makes installation easier IMO since you don't have to fight the tension of the coils.
