wiring trouble
Old Mar 29, 2015 | 08:10 PM
81powerram's Avatar
81powerram
Default wiring trouble
in desperate need of help with this wiring. the original owner butchered the wiring and i just want to get it running. i need to know what i can straight wire just to make it run. the whole ignition system is new. just need to know what to hook to. can i cut out this horrible fusible link and take my 2 main ignition feeds and go straight to the ballast. i have parts on order to make the HEI conversion but would like to use the molar performance system for now. any help is appreciated at this point.
Thanks,Martin
Attached Thumbnails wiring trouble-truckw2.jpg   wiring trouble-truckw3.jpg   wiring trouble-truckw.jpg
Old Mar 30, 2015 | 01:01 PM
Moparite's Avatar
Moparite
The ignition gets 12v from the key, It gets recused power during run that's where the resistor comes in. It gets full power during the crank position. Wire it correctly and don't get rid of the fuseable links. Getting an hei set up is no upgrade just a different configuration. If you want an improvement go with a MSD6A.
Old Mar 30, 2015 | 05:35 PM
81powerram's Avatar
81powerram
Thank you so much Moparite this is the exact information i was looking for. even tho i tired I'm defiantly going to work on my truck after work. also thanks for the heads up on the HEI. even tho i already ordered the parts ill go with the MSD6A go thing i only spent 56$ on the parts. once again thanks very much for the help its greatly appreciated. i owe you a few 6 packs.
thanks Martin
