93' D 150 Clutch Problem
friends 93 Dodge pickup with a manual and a granny low , was making noise i think from the throw out bearing. then they found some small ball bearings on the drive way. not able to disengage the clutch. but if you start it up in gear, feels like the clutch is being pushed in and out as you drive in low gear.
what give?
it's 4x4, has a slave for clutch pedal.
318, looks all original yet.
there's no inspection cover, so will have to pull trans out to see whats going on.
what give?
