1st Gen Gas front leveling
Old Sep 4, 2015 | 09:44 AM
blaster900's Avatar
blaster900
Default 1st Gen Gas front leveling
I have a 92 W350 360 and since its a 1ton pickup the back is up and the front looks like its pointing down. Im not looking to lift the back so id there anything to level the front with the back.
Old Sep 9, 2015 | 09:29 PM
Big Red Express's Avatar
Big Red Express
Put about 600lbs in the bed.... Problem solved! Just kidding. If you are interested in leveling the truck out look into leveling kits. Something to keep in mind though, depending on what you are using the 1 ton for... When you go to put a load in it, it will bring your rear end under the front end and strain your drive line. I have a 86 3/4 ton and has the same look (rear higher than front) but with a load, the truck levels out and handles great.
Old Sep 12, 2015 | 11:57 PM
KevenP's Avatar
KevenP
I agree with the post above.
However, if you really want to level the truck, just add longer rear shackles.
They'll drop the rear about 2".
