90 w350 have to wake it up to start
Old Nov 26, 2015 | 11:10 PM
LTJAX's Avatar
LTJAX
Default 90 w350 have to wake it up to start
90 w350 360 gas efi 727. Having trouble starting but once it starts runs perfect and starts perfect until I let it sit say overnight. Checked all wiring, cleaned and used dielectric on all connections. All fusible links ok. Have replaced: cap, rotor, plugs, wires, coil, pick up, ASD, ignition switch, fuel pump. Added new grounds from body to frame. Cleaned all ground connections. To get this thing started I have to cycle the key like 50 times. First the ASD will "wake up" then a few more cycles will get the idle speed motor and fuel pump to "wake up". Then it starts and runs great until I let it sit for a few hours. PCM????? Im totally perplexed
