overdrive solenoid not working
Old Mar 8, 2016 | 12:53 PM
carlrw's Avatar
carlrw
Default overdrive solenoid not working
hi im new to the forum i just bought a 91 w150 with 318 that has 3 speed with overdrive. The other day I noticed od wasn't engaging checked solenoid plug and it wasn't plugged in, i plugged it in and the truck wouldn't start then plug started smoking and melted together wondering if anyone has had this problem
Old Mar 8, 2016 | 05:41 PM
Moparite's Avatar
Moparite
There is a short inside the trans that's why it was disconnected. You may now have damaged the pcm also. Need figure out the problem in the trans and go from there.
Old Mar 8, 2016 | 07:14 PM
carlrw's Avatar
carlrw
Any recommendations on what to test I have no transmission experience so any help is appreciated
Old Mar 9, 2016 | 09:01 AM
Moparite's Avatar
Moparite
Get a manual for the truck, It will explain a lot and have a wiring diagram. You need to drop the pan and valve body then inspect/investigate where the short is. This is still an hydraulically controlled trans for the most part so it's not to difficult.
Old Mar 9, 2016 | 09:51 AM
carlrw's Avatar
carlrw
Ok I have a Haynes manual I'll try and find thanks for the help I'm assuming I should get a new solenoid before I do this
