My 1991 dodge d150 318 tbi won't start.
Old Mar 15, 2017 | 07:45 PM
rgaines57's Avatar
rgaines57
Default My 1991 dodge d150 318 tbi won't start.
If I pour a little gas into the throttle body it will kinda start and sputter so I know it is getting fire. I replaced the fuel pump 6 months ago. I disconnect the wires at the fuel pump and blue/yellow wire has 12volts. But I don't know if that is the feed for the fuel gauge or if that powers the pump. does anyone have a wiring diagram for the fuel pump with colors identified.
Old Mar 16, 2017 | 08:51 AM
robertmee's Avatar
robertmee
Post in the correct forum and you might get better help....This forum is for Dakota's, not Rams, so sorry, I only have wiring familiarity with Dakotas. I can tell you on mine, the pump is two wires, 16AWG, Dark Green/Black and Grey. The Fuel sending wires are all 18 AWG. Since the pump is a motor, it likely will be the larger two wires on your pump pigtail also.
Old Mar 16, 2017 | 09:27 AM
Moved to the correct section.
