Heater a/c not working
Old Jan 13, 2018 | 04:31 PM
PowerRam92's Avatar
PowerRam92
Default Heater a/c not working
Seen a lot of this around other forums with what seems like no solution. so maybe you guys would know where I could find one or what would work. I'm looking for a blower motor resistor. Part #4163761. I'm hoping that's the culprit anyway. I can hear it all working, as in, switching from a/c to heat and from vents to defrost, but motor is not kicking on. Can't find one anywhere, AutoZone, napa etc. Anyone know nowadays where I could find one? Or if I found a 5 prong resistor like the one I have, could I cut and crimp on a female wire clip and wire it in? Or would that not work?
Old Jan 13, 2018 | 05:41 PM
crazzywolfie's Avatar
crazzywolfie
best to start by checking power at the fuse panel. it is a common failure point. with the key on it should have power if not then it is a fusible link. if it has power if could be the heater control switch. it is common for those to overheat and fail. i would start with this and work from there.
