Lean Burn Computer
Old Feb 15, 2018 | 11:21 AM
jimmyisright's Avatar
jimmyisright
Default Lean Burn Computer
Can I replace the lean burn computer with a HEI distributor with vaccuum advance? I have a 1987 D150 with a carbed 318. Thanks
Old Feb 15, 2018 | 11:57 AM
crazzywolfie's Avatar
crazzywolfie
yes you can but some HEI distributors do not fit these trucks without massaging the firewall a bit. you might also need to swap the carb with a non computerized carb since i think the lean burn carb has a couple parts in it that are computer controlled. without the computer things may not run as it should.
Old Feb 15, 2018 | 01:16 PM
jimmyisright
Thanks crazzywolfie, Maybe instead of an HEI I should go old school. Jegs has electric ignition kits for reasonable prices.
Old Feb 15, 2018 | 02:01 PM
crazzywolfie
if the HEI setup does not have the coil built in it should probably work and fit no issue but i do know some people like the simplicity of the 1 wire distributor like the ones used on most older chevy's
Old Feb 15, 2018 | 06:21 PM
Moparite's Avatar
Moparite
If you visit your local junk yard you can get everything in this kit.
https://www.classicindustries.com/product/mn1113.html
Info on the leanburn..
https://www.allpar.com/mopar/lean-burn.html
