No power to coil or fuel pump
Old Feb 20, 2018 | 12:09 AM
Riedel’s livestock's Avatar
Riedel’s livestock
Question No power to coil or fuel pump
I have a 1992 ram 2500 it will crank and crank but not getting power to the coil or fuel pump where should I start to look?
Old Feb 20, 2018 | 06:42 AM
Moparite's Avatar
Moparite
The asd relay.
Old Mar 13, 2018 | 06:38 PM
Patrick Beuttler's Avatar
Patrick Beuttler
Default No spark
93 ram 5.2 4x4 been sitting for 3 years. It wouldn't even crank until I replaced starter relay and now cranks. Replaced distributor cap, rotor, ignition coil and all relays. Still no spark. Thinking it's the PCM/ECM/ECU computer but don't want spend too much $ until I can rule out the simple stuff .Thanks.
