I need help serious cold start issues 318
I'll check this out but wondering would this only cause issues while cold
11 Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking
it never hurt to check the timing but i doubt it has skip a tooth with only 90k miles on the clock. i would guess your issue may be with the code 54. probably best to try resetting the computer first to clear the codes so the computer can relearn with the new sensors in place
I'm in it right now ran okay cold got nearing operating tempeture and the issue has started it also has some kind of a snap crackle pop metal sound from engine when it does this I am hoping it will clear up soon really need to get to work
It also ticks regularly and loud it might just be time for a new engine at this point
Itd from the front of the engine probably timing chain what kills me is that she wants to live and be driven no matter how long it takes she will run
