Coolant Sensor Problems
Old Jun 24, 2019 | 09:45 PM
crazzywolfie's Avatar
crazzywolfie
look to the left of that heater hose. temp sensor should be hiding on the intake behind the a/c pump. a/c always makes them harder to change and see.
Old Jul 1, 2023 | 10:21 PM
Ray Wilson's Avatar
Ray Wilson
I finally got the truck back after a long stint in storage!
I started tuning it up and was fixing a small leak from the upper radiator hose to the thermostat.
While doing so I found two cut wires. I traced the wires back to running into a wire harness I believe goes to the firewall (see photos).
Could this be the temperature sensor and it was cut?? Thanks!
Cut wires were laying next to the thermostat. I traced them to this plug.
Wires eventually lead to this harness, which I think goes up eventually into the firewall (maybe to the temperature gauge?)
Old Jul 2, 2023 | 01:25 AM
Ray Wilson's Avatar
Ray Wilson
Update!! I am 99% sure I found the gauge temperature sensor behind the alternator. I’m going to change that, which will be a pain in the ***.
But I still want to know what those two wires go to! Those two wires were laying very suspiciously next to an empty, threaded hole near the thermostat. (See picture, yes I know I’m leaking coolant, new part on the way).
Here is the link to the forum post where I found the sensor location.
https://www.dodgetalk.com/threads/coolant-temperature-sender-location-318-engine.656734/#lg=attachment_xfUid-1-1688274832&slide=0
Empty hole right above the leaking thermostat
Old Jul 2, 2023 | 07:20 AM
crazzywolfie
Old Jul 2, 2023 | 09:12 AM
Ray Wilson's Avatar
Ray Wilson
A/C Compressor, interesting… I’ll go look. I hope you’re right!
