Need help ASAP
Old Aug 7, 2019 | 02:49 PM
adarnell73's Avatar
adarnell73
Default Need help ASAP
I have a 93 D250 with the Cummins. Just had the Injector Pump replaced 50-100 miles ago. ($1700). Yesterday my idle went high. Around 1500RPM. It is steady (1500) at Idle and when I come to a light I have to fight the truck to slow down. I am worried about driving it as I don't want to slam it into gear when it is idling that high. Had it towed home.
Where should I start with the troubleshooting? I have a small fuel leak at the fuel filter and will be buying a new one today. All the linkage is tight. I have not touched the engine since the pump install.
Old Aug 7, 2019 | 03:40 PM
crazzywolfie's Avatar
crazzywolfie
who did the pump install? is the throttle linkage moving as it should and not stopping anywhere or holding the throttle open? there is a throttle adjustment but from my experience it is pretty tricky to get at and probably shouldn't cause a huge difference in idle speed.
Old Aug 8, 2019 | 09:35 AM
adarnell73's Avatar
adarnell73
Took the truck to a shop that specialized in older Cummins. The linkage is perfect.
If it were a gas engine I would say the choke is stuck open. It idles nice and smooth at about 1500 instead of 750. When driving and slowing I have to hammer the brakes and she tries to keep going.
Old Aug 8, 2019 | 10:02 AM
crazzywolfie
sounds like you need to be talking to the shop that did the work. they must have done something wrong
