1990 D250 auto trans not shifting
Old Nov 12, 2019 | 05:23 PM
d250vin5's Avatar
d250vin5
Red face 1990 D250 auto trans not shifting
I have a 1990 D250 Vin5 with a 5.9 I have a automatic transmission problem. When it is cold it works fine but after 5 miles at 65MPH or so on the freeway it starts shifting back to 2nd gear. I'm not sure but I may have put in a quart of ATF instead of ATF+4 a while back but it had been working fine for some time. This problem started when I was moving from southern California to Northern California about 50 miles into the trip.I would be very greatfull for any ideas of what could be causing this.
Old Nov 12, 2019 | 06:58 PM
crazzywolfie's Avatar
crazzywolfie
what transmission is in it? if you have a 727(3speed) that shouldn't have hurt it. that is what is recommended in a 727 or any older transmission. usually the atf+4 is only needed in trucks with overdrive. does the transmission fluid smell burnt?
Old Nov 13, 2019 | 05:25 PM
d250vin5's Avatar
d250vin5
It is an A518 (46RH) which does have overdrive and the fluid does not appear or smell burnt.
Old Nov 14, 2019 | 06:40 AM
Moparite's Avatar
Moparite
When was the filter changed last? You might want to do a pressure test and see what you have.
https://www.trucktransdiag.com/downl...nsmissions.pdf
Old Nov 14, 2019 | 12:59 PM
d250vin5's Avatar
d250vin5
Talking
I really don't know when or if the filter has been changed. I think I will try changing it since that may be the most cost effective place to start.
