87 D150 Brake Booster
I have a chance to get an 87 D150 (w/318) that belonged to my grandfather. The truck will be free to me, but to get it drive-able enough to make it to my house I need to find a new power brake booster.
I've been scouring the internet for a new/re-manufactured booster and have had zero luck.
Most websites are saying I need this part and claim it is specific to the 86-87 model years, they are also all out of stock and say the part is discontinued: https://www.rockauto.com/en/moreinfo...sn=598&jsn=598
I used some salvage websites to look up parts interchangeability and that said I could use any booster from model years 84-93 and it should fit.
I can find brake boosters for the 90-93 model years quite easily, doe anyone know if these years would work? Would I also need to get a master cylinder from the same model year range? Or do I need to keep searching for this unicorn of a part?
Thanks,
Jared
Thanks,
Jared
you should be able to drive it without the booster working. you just have to drive a bit more cautiously since you won't have power brake and have to press the peddle a lot harder to make it stop. master cylinder lists being the same from 79-93 so i would assume brake booster should be the same. only thing i think i have come accross changing is the hole/fitting on the brake booster. that may be the reason it was a 2 year only part.
