1983 318 Pan Removal 4x4 Auto Trans
Old Oct 3, 2020 | 10:16 AM
James Jamie Soule's Avatar
James Jamie Soule
Default 1983 318 Pan Removal 4x4 Auto Trans
Thinking about dropping the pan for inspection/cleaning and resealing - I believe I can do front seal fairly easily when doing this, yes? Anything else to consider when doing this? Thanks - been many years since I have worked on V-8's
Old Oct 3, 2020 | 09:03 PM
James Jamie Soule
Ooops, meant front pan seal not front crank seal
Old Oct 10, 2020 | 11:57 PM
volaredon's Avatar
volaredon
yup. a necessity to change that seal when pan pulled. that applicarion is a pretty easy pan-pull with engine in frame. a B van is about the next easiest..... talk 2wd Dakotas? those suck to try and pull the pan in chassis.
