1983 AC Evaporator Clean Out - Best Location to Cut and Expose Evap?
Old Oct 24, 2020 | 05:09 PM
James Jamie Soule's Avatar
James Jamie Soule
Default 1983 AC Evaporator Clean Out - Best Location to Cut and Expose Evap?
I have working R-12 but I know my evap is packed with debris based upon the huge amount of leaves I have pulled out of side vents, cowl and behind blower motor - best place to drill on an '83 to access view of evaporator so I can shoot with coil cleaner etc. Anyone do this recently with an older truck? My truck is an '83 w250 - will most likely cut out with hole saw and use large grommet to reseal.
Old Oct 24, 2020 | 06:00 PM
James Jamie Soule
Can anyone tell me where about to cut for optimal exposure to evaporator coil ?- it is going to be packed with dirt, guaranteed!
Old Oct 25, 2020 | 08:25 AM
Moparite's Avatar
Moparite
Best bet is to remove it and completely disassemble it. Even if you cut a hole you wouldn't be able to get everything out. And with a truck that old all your foam seals are non existent.
Old Oct 25, 2020 | 11:03 AM
James Jamie Soule
Any idea where it is located moparite? The first gen cummins guys do this and it is quite effective. No time to pull it out, I want to vac it and shoot coil cleaner through it and let it drain, rinse, repeat.
Old Oct 26, 2020 | 11:26 PM
James Jamie Soule
Success! I was able to measure from engine bay inner fender wall to Evap ports and also located condensate drain connection which was under plenum inside cab, I was able to see just enough of the drain connection to determine where to make my cut. I made a small pilot hole and carefully just broke the surface of plastic air plenum box to determine how much room I had on the other side - Using a 3 inch hole saw and allowing about 1/4 of pilot drill by adjusting, I cut a neat hole and voila! Evap! The Cummins first gen folk use large firewall grommets to seal- need to track one down.
I was able to use hot water from a garden sprayer and coil cleaner to flush the evaporator well - lots of junk ran out and there was quite a bit of leaves and dirt which I vacuumed out first. Nice clean evaporator which I can service annually.
