d150 3.9 v6
Old Jan 12, 2021 | 11:18 AM
Ethan gilman's Avatar
Ethan gilman
Default d150 3.9 v6
i have a 90 d150 with the 3.9 v6 and it dies on me sometimes. i drive a while and its fine then its only when i take off then it dies. i know when it does this its not getting fuel the fuel pump does not run and then i can wait a while and itll go again im thinking its a loose wire. if you have had this problem and know where it happend or what is going on i could use the help. thank you
Old Jan 12, 2021 | 06:21 PM
Moparite's Avatar
Moparite
Pump could on it's way out.
Old Jan 12, 2021 | 07:33 PM
ol' grouch's Avatar
ol' grouch
Swap the fuel pump relay with the a/c relay. If the problem goes away, get a new relay and put the a/c back and the new one in the fuel pump relay position. If it doesn't make any difference, your pump may be going out.
Old Jan 13, 2021 | 09:21 AM
Ethan gilman
thank you sounds great ill give it a shot.
Old Jan 13, 2021 | 03:17 PM
crazzywolfie's Avatar
crazzywolfie
could also possibly be the hall effects sensor in the distributor.
Old Jan 14, 2021 | 09:41 AM
Ethan gilman
is there an easy way i could check that?
