1986 D250 5.2l fluids
Old Feb 14, 2022 | 11:10 AM
Brandy956's Avatar
Brandy956
Default 1986 D250 5.2l fluids
Hi, I just bought 1986 Dodge D250 with 5.2 litre (318ci) engine with manual transmission and RWD and I need to change all fluids. Does anyone know the engine oil capacity, transmission oil capacity, coolant capacity and differential oil capacity?
Old Feb 15, 2022 | 06:08 PM
ol' grouch's Avatar
ol' grouch
If you got lucky and an owners manual came with it, that will be in there. Usually, your engine will be either 5 or 6 quarts with filter. The transmission and differential you will fill until it runs out. 75W-90 for the rear end. Some transmissions used ATF and some used gear oil. That depends on what transmission you have. Do you have a sur-grip or open rear end? The sur-grip needs a friction mollifier to operate properly.
Last edited by ol' grouch; Feb 15, 2022 at 06:09 PM. Reason: i kant spel wurth a durn
