Intermittant Headlights
Old Oct 13, 2022 | 01:49 PM
James Jamie Soule's Avatar
James Jamie Soule
Default Intermittant Headlights
I understand that our light switches can be the culprit for intermittent non op headlights (my truck is an '83) Is it a matter of reflowing the solder or other. Are new switches still available or other? Thanks!
Old Oct 13, 2022 | 02:39 PM
crazzywolfie's Avatar
crazzywolfie
i would be looking at the dimmer switch on the floor. most common cause of headlights not working.
Old Oct 13, 2022 | 11:22 PM
James Jamie Soule
Yep, there is no "click" function (detent broken) with high low switch and one mount broken on floor switch - time for a new one, will test in the am-thanks
Old Oct 15, 2022 | 10:01 AM
James Jamie Soule
Yep, pulled floor switch, oem, plug a little burnt and melted slightly, picked up a new switch at Napa and also a 3 prong plug and wired in - all good now, thanks Wolfie!
Old Oct 15, 2022 | 08:08 PM
crazzywolfie
no problem. like i said it is a common issue because of the location. i sometimes try to fill them up with lithium grease to help keep moisture. i also keep a couple on hand just in case since they are cheap. it may also be worth installing a headlight relay harness under the hood to take some stress of the dimmer switch connector. it can also in some case make a noticable difference to the light output of the headlights.
