1989 dodge d350 vaccum lines
Old Jan 7, 2023 | 05:15 PM
DodgeDriver123's Avatar
DodgeDriver123
Default 1989 dodge d350 vaccum lines
I have a 1989 dodge d350 with 5.9l v8 and was wondering where i could get a diagram and also what vacuum lines I need to keep and / or can remove, I also want to know how to remove the smog stuff for the emissions because nothing on my truck is hooked up.
Old Jan 8, 2023 | 09:10 PM
ol' grouch's Avatar
ol' grouch
You probably have the A.I.R. pump. Since that's a Federal emissions system, you can't take it off. That means you can't take the belt off. You can't unplug the vacuum lines to the pump and plug them with golf tees and tape them in place with electrical tape. A lot of people will leave that little pump in place if they wanted to disable the system. You also don't want to remove the hose going to the exhaust manifold and cover the end with a couple of layers of aluminum foil.
Old Jan 12, 2023 | 10:01 PM
u2slow's Avatar
u2slow
People remove emissions equipment all the time.
The catch is, if you're ever faced with a vehicle inspection, you may have to put it back on.
Here is a thread about deleting...https://www.ramchargercentral.com/th.../#post-3555590
Old Jan 13, 2023 | 11:29 AM
ol' grouch's Avatar
ol' grouch
I met a guy from St. Louis that took his AIR pump apart and took the innards out. He put a pulley on a shaft and reinstalled the pump, hoses and belt. It does nothing but look good enough to pas inspection.
