87 d150 5.2 318 vacuum lines.
Old May 3, 2023 | 09:42 PM
Anthony87d150's Avatar
Anthony87d150
Default 87 d150 5.2 318 vacuum lines.
Need help identifying the vacuum lines in picture. What does large main hose on top go to(this is a picture of one I found online mine has a broken hose) I have it plugged and it’ll run rough, unplugged and it’ll shut off on me.
I
Old May 4, 2023 | 11:18 PM
crazzywolfie's Avatar
crazzywolfie
the big one goes to the power brake booster.
Old May 5, 2023 | 09:25 AM
Anthony87d150
Diagram shows line connects from passenger side of carb though.
Old May 5, 2023 | 01:25 PM
crazzywolfie
it would be up to you to verify if your setup is different than the diagram. that is how it is on most vehicles i have worked on.
Old May 5, 2023 | 09:04 PM
Anthony87d150
Ok if I do how you recommend (which I’ve seen a bunch of people do this for way as well) can I just plug the right side of carb?
Old May 6, 2023 | 07:58 AM
crazzywolfie
ya just install a vacuum cap or block air from going in there and it should be fine.
