Dana 44 Steering Arm
Old May 8, 2023 | 02:24 PM
jtpasto's Avatar
jtpasto
Default Dana 44 Steering Arm
Dana 44 Steering Arm is difficult to remove with the cone shaped washers. This simple tool can be made by flattening a piece of coat hanger wire and grinding it to a point. Use it to clean out the slot in the cone shaped washers. The cleaned slot gives better access for penetration of chemicals like PB Blaster. Not that this is the fix all, but it helps.
