Dana 60 in the junk yard
Old Jan 31, 2006 | 12:50 PM
cudahob4's Avatar
cudahob4
Default Dana 60 in the junk yard
It's out of a 91 Ram 2500.
The 6 lug Dana is a posi, is it worth pulling? Will it bolt in my 92 Dodge 1500 easily?
Cost would be about $60.
Old Feb 1, 2006 | 03:58 PM
horatio102's Avatar
horatio102
Default RE: Dana 60 in the junk yard
6 lug? Pretty sure only Dakotas and Durangos (in the dodge side) had 6 lug axles, 8 3/4 or 9 1/4 for rear and D44 up front. The 2500 should have 8 lugs.
Is it worth pulling? Yeah, if the axle is straight, the bearings and seals are good, and the brakes are complete.
What's wrong with your 9 1/4? The brakes on the D60 are bigger, the spring pads might be wider, the U-bolts may need to be different (depending on how it's all bolted together - the D60 has a larger axle tube iirc, so if the bolts aren't wide enough they won't fit), you may need to get a combo u-joint for different sized yokes between the driveshaft and the axle, etc. It's not going to be a direct swap, but it's not too terribly difficult either. Just be aware that there are a lot of things that may be quite different. Plus you'll need to get new wheels.
Old Feb 5, 2006 | 01:47 PM
cudahob4's Avatar
cudahob4
My 9 1/4 is just fine, but I wanted a sure grip. I'm going to tow a trailer one day, and would like the Big dana.
I didn't know how common they are to have sure grip, or do they all have it?
Yeah, I think it had the 8 lug, and not 6.
Thanks man
ch
Old Feb 5, 2006 | 08:34 PM
horatio102's Avatar
horatio102
I don't think the sure grip is all that common, especially in the older ones.
